1 - 4 of 4 Posts
sorry i want'a ask something
im new overclock in here
i want'a ask, this is normal vcore max 1.2xx and core speed 3,6 ghz ?
im afraid is this excessive? and if this overclock can damage my proci or motherboard ?
thanks
Super Moderator
Not even close to dangerous. That's actually quite low.
Lost In A Void Of BSOD's
Just slowly raise your clocks on your cpu little by little and test it for 10-15 minutes with something like ROG Realbench. if it doesnt crash and passes then raise it more. do it until you crash. final stability testing should be a few hours running the test to verify stability. there are tons of guide that go into more detail on the forums here and such but i hope this helps.
1 - 4 of 4 Posts
