Help! Tried everything!
262 Views 2 Replies 3 Participants Last post by  Powelly
Ok guys im in a hectic situation and need some assistance. 1X320gb, 1X500gb both seagate 7200.11. The 500gb just doesn't pick up,like its not even there. Heard its a common problem with the 7200.11's firmware. I had xp on both drives, 500gb as my main os and when the 500gb died it doesn't load xp from my 320gb it gives this msg
"Reboot and select proper boot device or insert boot media in selected boot device and press any key"
I flashed to rf403 bios which was the most reliable on my p5e, i cleared cmos, discharged the board and still the same, i reinstalled windows on an old ata 40gb seagate, same. I don't know what else to try. I'm starting to think that the hdd messed my mb up. I'm getting a 1.5tb seagate soon, will try with that once i get it, i don't know what else to do and i need my pc operational. Before my pc wouldn't shutdown, it would just restart instead of shutting down and the only way to put it off was with the psu switch, i thought it was the psu coz ultimately it controls on/off state, i ordered a new 750w psu coz of that, but when i was installing xp on the 40gb it shutdown just fine so im thinking its either bad hdd/ hdd firmware/ os/ mb/ virus that caused the shutdown problem. Do you think it all could be linked to the bad hdd or even a virus.? Im running out of options and need assistance badly. Any help is highly appreciated, lets hope we can get this problem sorted out, im goin to post this in the windows, hdd and mb sections in the hopes that any expert could point me in the rite direction. Thanks
1 - 3 of 3 Posts
hmm well you know that cutting the power off from your pc isnt the proper way to turn your pc off. There is a reason why you shouldnt do that. Maybe its your hdd. Try and ask in a shorter sentence. Short and sweet to the point
Try installing an alternative OS to see if the drive/board is corrupted?
Try Vista first if it's available, if not try Ubuntu
Also, try booting from the XP cd and going to recovery console - if you can get there you may want to a) Chkdsk and b) Fixboot...
1 - 3 of 3 Posts
