Help troubleshooting UT3 shutdowns!!!
442 Views 7 Replies 5 Participants Last post by  Maddog7771
I play mostly UT3 these days and recently i got this annoying problem where after about half an hour sometimes an hours playing the game suddenly crashes mid-play.
Iam using the latest WHQL drivers 182.08.
My Ultra is slightly OCd and peak temps are less than 90c which is very good for an Ultra I think. (recently got a new PCI slot cooler for it)
My CPU is OCed an peak temps are 65c with P95.
RAM is Not OCd
I looked in Problems reports and Solutions an the following is the error report for UT3.
Description
A problem caused this program to stop interacting with Windows.
Problem signature
Problem Event Name:AppHangB1
Application Name:UT3.exe
Application Version:0.0.0.0
Application Timestamp:48918540
Hang Signature:9cdd
Hang Type:2048
OS Version:6.0.6001.2.1.0.256.1
Locale ID:1033
Additional Hang Signature 1:58716be464dca91f8e7e94f384ddfcdb
Additional Hang Signature 2:6ff6
Additional Hang Signature 3:eacae13fceb07efeed78155e77b95bd2
Additional Hang Signature 4:9cdd
Additional Hang Signature 5:58716be464dca91f8e7e94f384ddfcdb
Additional Hang Signature 6:6ff6
Additional Hang Signature 7:eacae13fceb07efeed78155e77b95bd2
can anyone make heads or tails ouuta this?
Before anyone asks I played Crysis and no crashes so far, but I really don't play it as long as UT3.
Any help would be highly appreciated an repped.
Thanks
SWLS
1 - 8 of 8 Posts
Memtest
I've heard of this game crash randomly before while other games worked fine.
Is the game patched?
I had the same problems. I played around with some video settings, and I believe checking "frame rate smoothing" worked for me. This is a common problem. Some people also said underclocking the video card worked also. Try that if my trick doesnt work for you.
yeah its got the latest patch.
OK I solved it.
My RAM was running at 2.2v when its supposed to run at 2.3v.
Also I upped the CPU voltage in the BIOS to 1.475 from 1.425.
Dunno which was the culprit. but now it works.
yeah i was gunny say i had the same issue and adjusted the ram and boom and it also had to do with drivers for me to
1 - 8 of 8 Posts
