My motherboard is Intel Pendleton D845PT Socket 478 Pin, FBS 400, i am using a intel p4 1.8ghz at the mo and i do not know which CPU to the which will work with this which is the best cpu i can get for this mother board, i have looked on ebay and the following items have tempted me:-
Intel P4 2.4 GHz 512/800 CPU socket 478
Intel P4 2.53 GHz 512/533 CPU socket 478
P4 Intel® Celeron 2.5 Socket 478 CPU 400 FSB
Intel Pentium 4 P4 3.2 3.2GHz CPU SOCKET 478
3.4GHz Intel P4 socket 478 1MB/800MHz NR
Intel Pentium 4 P4 2.53-Ghz 533 478-pin SL6D8 Northwood
Intel P4 3.2Ghz HT, 478 pin
Intel Pentium 4 (P4) 2.8 ghz HT CPU Hyper-Threaded 478
The details on my Motheboard is below
--------[ CPU ]---------------------------------------------------------------------------------------------------------
CPU Properties:
CPU Type Intel Pentium 4, 1800 MHz (18 x 100)
CPU Alias P68, Willamette, A80528
CPU Stepping D0
Instruction Set x86, MMX, SSE, SSE2
Original Clock 1800 MHz
Engineering Sample No
L1 Trace Cache 12K Instructions
L1 Data Cache 8 KB
L2 Cache 256 KB (On-Die, ECC, ATC, Full-Speed)
CPU Physical Info:
Package Type 478 Pin uPGA
Package Size 3.50 cm x 3.50 cm
Transistors 42 million
Process Technology 6M, 0.18 um, CMOS
Die Size 217 mm2
Core Voltage 1.75 V
I/O Voltage 1.75 V
Typical Power 55.3 - 75.3 W (depending on clock speed)
Maximum Power 72 - 100 W (depending on clock speed)
CPU Manufacturer:
Company Name Intel Corporation
Product Information http://www.intel.com/products/browse/processor.htm
CPU Utilization:
CPU #1 0 %
--------[ CPUID ]-------------------------------------------------------------------------------------------------------
CPUID Properties:
CPUID Manufacturer GenuineIntel
CPUID CPU Name Intel(R) Pentium(R) 4 CPU 1.80GHz
CPUID Revision 00000F12h
IA Brand ID 08h (Intel Pentium 4)
Platform ID 0Eh (Socket 478)
IA CPU Serial Number Unknown
Microcode Update Revision 2E
HTT / CMP Units 0 / 0
--------[ Motherboard ]-------------------------------------------------------------------------------------------------
Motherboard Properties:
Motherboard ID 51-2300-000000-00101111-030199-$D845PT_
Motherboard Name Intel Pendleton D845PT
Front Side Bus Properties:
Bus Type Intel NetBurst
Bus Width 64-bit
Real Clock 100 MHz (QDR)
Effective Clock 400 MHz
Bandwidth 3200 MB/s
Memory Bus Properties:
Bus Type DDR SDRAM
Bus Width 64-bit
Real Clock 133 MHz (DDR)
Effective Clock 267 MHz
Bandwidth 2133 MB/s
Chipset Bus Properties:
Bus Type Intel Hub Interface
Bus Width 8-bit
Real Clock 67 MHz (QDR)
Bandwidth 267 MB/s
Motherboard Physical Info:
CPU Sockets/Slots 1
Expansion Slots 3 PCI, 1 AGP
RAM Slots 2 DIMM
Integrated Devices Audio
Form Factor Micro ATX
Motherboard Size 210 mm x 240 mm
Motherboard Chipset i845D
Motherboard Manufacturer:
Product Information http://www.intel.com/design/motherbd/index.htm
BIOS Download http://www.intel.com/design/motherbd/genbios.htm
--------[ Memory ]------------------------------------------------------------------------------------------------------
Physical Memory:
Total 767 MB
Used 299 MB
Free 467 MB
Utilization 39 %
Swap Space:
Total 1877 MB
Used 455 MB
Free 1421 MB
Utilization 24 %
Virtual Memory:
Total 2645 MB
Used 755 MB
Free 1889 MB
Utilization 29 %
Physical Address Extension (PAE):
Supported by Operating System Yes
Supported by CPU Yes
Active No
--------[ Chipset ]-----------------------------------------------------------------------------------------------------
[ North Bridge: Intel Brookdale i845D ]
North Bridge Properties:
North Bridge Intel Brookdale i845D
Revision 04
Package Type 593 Pin FC-BGA
Package Size 3.75 cm x 3.75 cm
Core Voltage 1.5 V
In-Order Queue Depth 12
Memory Timings:
CAS Latency (CL) 2.5T
RAS To CAS Delay (tRCD) 3T
RAS Precharge (tRP) 3T
RAS Active Time (tRAS) 6T
Error Correction:
ECC Supported, Disabled
ChipKill ECC Not Supported
RAID Not Supported
ECC Scrubbing Not Supported
Memory Slots:
DRAM Slot #1 256 MB (DDR SDRAM)
DRAM Slot #2 512 MB (DDR SDRAM)
AGP Controller:
AGP Version 2.00
AGP Status Enabled
AGP Device Pine Tech. GeForce FX 5200
AGP Aperture Size 64 MB
Supported AGP Speeds 1x, 2x, 4x
Current AGP Speed 4x
Fast-Write Supported, Enabled
Side Band Addressing Supported, Enabled
Chipset Manufacturer:
Product Information http://www.intel.com/products/browse/chipsets.htm
Driver Download http://support.intel.com/support/chipsets/index.htm
[ South Bridge: Intel 82801BA ICH2 ]
South Bridge Properties:
South Bridge Intel 82801BA ICH2
Revision / Stepping 05 / B5
Package Type 360 Pin EBGA
Package Size 2.3 cm x 2.3 cm
Core Voltage 1.8 V
--------[ BIOS ]--------------------------------------------------------------------------------------------------------
BIOS Properties:
BIOS Type AMI
System BIOS Date 12/12/01
Video BIOS Date 01/27/04
BIOS Manufacturer:
Company Name American Megatrends Inc.
Product Information http://www.ami.com/amibios
BIOS Upgrades http://www.esupport.com/biosagent/in...m?refererid=40
Problems & Suggestions:
Suggestion Are you looking for a BIOS Upgrade? Contact eSupport Today!
Suggestion System BIOS is more than 2 years old. Update it if necessary.
Suggestion Video BIOS is more than 2 years old. Update it if necessary.
CPU Properties:
CPU Stepping D0
L1 Data Cache 8 KB
CPU Physical Info:
Die Size 217 mm2
Core Voltage 1.75 V
I/O Voltage 1.75 V
CPU Manufacturer:
CPU Utilization:
CPU #1 0 %
CPUID Properties:
Bus Width 64-bit
Bandwidth 3200 MB/s
Bus Type DDR SDRAM
Bus Width 64-bit
Bandwidth 2133 MB/s
Bus Width 8-bit
Bandwidth 267 MB/s
CPU Sockets/Slots 1
RAM Slots 2 DIMM
Physical Memory:
Total 767 MB
Used 299 MB
Free 467 MB
Utilization 39 %
Swap Space:
Total 1877 MB
Used 455 MB
Free 1421 MB
Utilization 24 %
Virtual Memory:
Total 2645 MB
Used 755 MB
Free 1889 MB
Utilization 29 %
Active No
Revision 04
Core Voltage 1.5 V
Memory Timings:
Error Correction:
RAID Not Supported
Memory Slots:
AGP Controller:
AGP Version 2.00
AGP Status Enabled
Core Voltage 1.8 V
BIOS Properties:
BIOS Type AMI
BIOS Manufacturer:
