1 - 2 of 2 Posts
Okay, I made the mistake of not researching my mobo purchase. So I am trying to make the best of my situation. In the BIOS Softmenu setup there is a Voltage setting for LDT. What is LDT? I was hoping it is the same as the chipset cause there isn't an option for that. Also, I am running an XP2400M and the multplier is locked @6 so I cant get the overall MHZ to go much over [email protected] 220without stability problems. Memory is Kingmax DDR466 dual 512's. What is the stock freq. on the 2400M? Any other suggestions would be appreciated.
I believe you are correct... chip set!
BTW... the "m" or mobiles are not locked.
There should be an option to use either User, Advanced or Expert to reviel the option to adjust the multiplyer.
Specs on the CPU you seek at the bottom part of link.
http://encyclopedia.thefreedictionar...icroprocessors
1 - 2 of 2 Posts
