I ran occto 3.0 and I have a question regarding one of the parameters . In the cpu section on the voltage row all my voltages appear correct (although vcore drops to 1.17 under load) except for the last one in the row . It looks like it should be 12v but at idle Im getting a little over 1 volt under load it goes up to around 6 but never reaches 12v . Is this a problem ,if so some suggestions as to the cause and correction would be appreciated
Thanks
Thanks
