Help Will Reward W/ Rep Pts.
503 Views 4 Replies 5 Participants Last post by  kickassclone
i need a good water block for S939. i plan on getting a koolance exos(i no i no the exos isnt the best but its good 4 the price) mayb theres a better(cheapr system)other than building the water coolin sys from scratch.will u plz help me out all help will b rewared w/ rep. pts!!!
1 - 5 of 5 Posts
Go for Danger Den, they are the best you can get for the price IMO. The TDX or RBX blocks.
ehh, i know you want a value system, believe me, i wanted one until i figured out how badly they performed. if you really want watercooling, then save up for a custom-built one, because cheap ones like the exos are comparable to a half-decent air setup...if i were you, i'd save up more money so you can build a good setup, like a dangerden kit. i'd go with a TDX CPU block, GPU block if you want, then a good pump (you choose), a heatercore (not a radiator, but a heatercore- keep that in mind), and a fan to blow on the heatercore to radiate heat...
hope this gets you started.
get a brass topped tdx. The lucite ones can crack over time and then you know what happens after that.
I have a brass topped one myself
. They are extremely nice and do a very good job.
1 - 5 of 5 Posts
