1 - 11 of 11 Posts
ok i got my ultra.. now i want to overclock.
my stock clocks are
core: 660
shader:1512
memory: 1150
so i want to know which program is the best to use with my card (its MSI if that matters)
what clocks should i go for?
if i overvolt how much is too much?
thanks in advance
Use ATITOOL, from what I understand it has its own scanner to detect artifacts. Every card is different when it comes to OCing so don't expect to get someone elses amazing results. There are too many steps to list in just one post, it would be a giant wall of text. The main concept is to raise the clocks up, one at a time, and test them for artifacting untill they can go no further. It's a rather tedious and time consuming project, but can yield some pretty amazing results. For a more in depth article, read this. As for volt modding, you will have to ask someone else.
Laptop Enthusiast
That's a powerful card there... I just looked it up and went... O_O
I am soooooo envying you right now... despite me having a 295, I still want that card... >.<
Where'd you get it?
Edit: For OCing use EVGA Precision and use GPUtool for artifact testing as it records how long ago the last artifact was found.
you can use ATITOOL with nvidia?
Indeed thumbhammer, I myself use ATITool. I use the artifact scanner and let it run for 20 minutes to see if its stable. To further check stability I let furmark run for an hour in full screen mode at 1400x900.
Overclocking
Where'd you get it?
i got mine off ebay.... just search and you will find plenty.
1 - 11 of 11 Posts
