Heys guys i have a problem and it started just today. When ever i play a game like ofp2 or cod4 ill play for about 5 min or less then my computer locks up so i hit the restart switch on my case and i get one long beep and two short beeps. witch means video card or monitor error. when i power off and turn it back on it boots up fine with no errors. any ideas whats going on. i get about 73C on a load.
Considering that you're not overclocking and everything's stock, I would check to see if you can RMA your card. Check with your brand's warranty specifications.
well i just took it apart. took the fan off and took the heatsink and ran it under hot water. it cleaned all the dust off im about to stress test it again and see if it crashes.
any luck? I hope you gave your card ample time to dry after running it underwater. if it's still under waranty try to RMA it, if not you could try to bake it or I'll pay for shipping and you can send it my way
I horde these dead 8800gts' for spare parts and the like
Overclock.net
