1 - 16 of 16 Posts
I am trying to make a bank account program using Java but I am new and stuck. It has to use two classes. So far I have this. It will allow me to input my starting balance and my name. Then it will let me choose either deposit or withdraw but then it skips right to the end rather than go to the if statement. What can I do so that it will go to the loop and define x and preform the correct equation? I'm also new so if my formating is crap, sorry.
public class BankAccount
    public double deposit (double balance)
       balance = balance + x;
       return balance;
    public double withdraw (double balance)
       balance = balance - x;
       return balance;
    public String name;
    public double balance;
    public double x;
import java.io.*;
import java.util.*;
public class Tester
public static void main(String [] args)
 Scanner kbReader = new Scanner(System.in);
 System.out.println("Enter amount of monet in account");
 double balance = kbReader.nextDouble();
 System.out.println("Enter name:");
 String name = kbReader.next();
 System.out.println("Withdraw or Deposit");
 String choice = kbReader.next();
if (choice == "Withdraw" )
    System.out.println("How much would you like to withdraw?");
     double x = kbReader.nextDouble();
 if (choice == "Deposit")
     System.out.println("How much would you like to deposit?");
 System.out.println("The " + name + " account balance is " + balance);
Discussion Starter · #6 ·
OK that helped a lot, thank you. However, now now whenever I run it, It prints the original balance that was input rather than the deposited or withdrawn amount. I think it's a failure of communicate between the two classes.
All you are doing is printing the variable name and balance as you entered them above.
You never use the class you created. Also you might want to put a constructor in that class
and then a way to create an instance of the class and associate it with the name of the account
examples
added constructor and changed methods to store values instead of returning them
added method to get balance
    private double balance;
    public BankAccount(double balance) {
        this.balance = balance;
    public void deposit(double balance) {
       this.balance += balance;
    public void withdraw(double balance) {
       this.balance -= balance;
    public double getBalance() {
        return this.balance;
import java.util.HashMap;
import java.util.Scanner;
public class Main
    public static void main(String [] args){
        HashMap<String,BankAccount> accounts = new HashMap<String,BankAccount>();
        Scanner reader = new Scanner(System.in);
        String name;
        double balance;
        while(true) {
            System.out.println("[Create] account");
            System.out.println("[Withdraw] money from account");
            System.out.println("[Deposit] money in accout");
            System.out.println("[Get] account balance");
            System.out.println("[q] to quit");
            String minput = reader.next();
            if ("q".equalsIgnoreCase(minput)){
                break;
            if ("create".equalsIgnoreCase(minput)){
                while(true) {
                    System.out.print("Enter name [c] to cancel: ");
                    name = reader.next();
                    if ("c".equalsIgnoreCase(name)){
                        break;
                    if (accounts.containsKey(name)) {
                        System.out.println("Account name is already in use");
                    else {
                        System.out.println("Enter amount of money in account");
                        balance = reader.nextDouble();
                        accounts.put(name, new BankAccount(balance));
                        break;
            if ("withdraw".equalsIgnoreCase(minput)){
                while(true) {
                    System.out.println("Enter name of account");
                    System.out.print("to withdraw from or [c] to cancel: ");
                        break;
                        System.out.print("How much would you like to withdraw? ");
                        accounts.get(name).withdraw(balance);
                        break;
                    else {
                        System.out.println("account name not found");
            if ("deposit".equalsIgnoreCase(minput)){
                while(true) {
                    System.out.print("to deposit into or [c] to cancel: ");
                        break;
                        System.out.print("How much would you like to deposit? ");
                        accounts.get(name).deposit(balance);
                        break;
                    else {
                        System.out.println("Account name not found");
            if ("get".equalsIgnoreCase(minput)){
                while(true) {
                        break;
                        System.out.println("Account balance for " + name + " is $" +
                                accounts.get(name).getBalance());
                        break;
                    else {
                        System.out.println("No accout with that name");
create an empty HashMap that will use a string as a key and an instance of BankAccout as the value
add the key,value pairs like so
deposit, withdraw, or get the balance by calling the methods on the instance of the class
tom.slick is correct about how you use the class. Before you were simply using it like a variable. The point of a class to be able to create an object, as he showed. However you don't need to use a hashmap, that is more complicated for you to understand. Simply declare one or more bankAccounts as follows:
BankAccount account1 = new BankAccount();
BankAccount account2 = new BankAccount();
and reference like
account1.getBalance();
To tom.slick - if he didn't know to correctly use a class, you shouldn't be describing a more complicated way of declaring an object in list or a hashmap. keep it simply for him. While it might be a better, cleaner way to do it, that is not what he is learning at the moment. People have to learn to walk before they can run. And if I was the instructor and I was teaching someone how to declare a class, and they came back with using a hashmap I would be suspicious of how they came up with that unless they excelled the entire time in the class.
Your right I should have kept it simple. I sometimes forget the steps in between and just solve the problem.
and reference like
If I would of turned in an assignment on classes with a hashmap in my Java class , my teacher would have given me a 0 unless I could run through the code line by line and explain the logic of it all haha.
Originally Posted by yui129 View Post
Thank you for simplifying it for me. Should I replace my methods with those?
A "trick" my teacher used to help the people in our class struggling with learning how classes worked, was making you remember that "String" variables aren't a primitive data type. Strings are a class, so any class you make must be used similarly to a String. So for this program, .getBalance() is comparable .equals() in the sense that they're both methods of the class. Hope this helped!
=D in my "Web pages for buisnesses" class they were teaching it using dreamweaver... The final basically had a page with a form that when you click submit it would validate the fields and send an email... but it really doesnt send an email because its linked to nothing. So, i decided to write mine with ASXP and C# in the backend where i linked it to my gmail account had my password converted into binary so even though i showed the code, my password wasnt clear text. My page actually emailed on the form submit. (And yes, i know i could have secured it a lotmore, but at least it was quick and easy.)
... It was sad to see that half the class come in wondering why their pages wouldnt work on this computer, but it worked at home. (Static Paths) ... sigh... class was a waste of time for me, but at least it counted for an elective.
Dealing with Bank Account? Need to discuss locking and cohesion!
And use of Decimal instead of Float and so on. Don't use Float for money related operations. Alternatively use int or long and save the currency in cents (e.g. $1.00 = 100 in int).
Originally Posted by gonX View Post
And use of Decimal instead of Float and so on. Don't use Float for money related operations. Either use int or long and save the currency in cents (e.g. $1.00 = 100 in int) as an int.
Excellent point! This got me once a decade ago when I was an intern writing a spreadmart to calculate a money market allocations.
He also probably should range checking to protect from negative withdrawals/deposits and overflows as well.
[Secure systems are hard!]
Depending on what language you're programming in, you should probably consider checking if your language supports something similar to the checked keyword in C#.
1 - 16 of 16 Posts
