1 - 5 of 5 Posts
I got a Phenom II X4 945BE for my friends build and we are going to build it tonight, and I'd like to know some information about AMD overclocking...
I know the basics (1.5V on air MAX) 60c MAX but the NB thing is a little unclear to me? What happens if I leave it on auto and overclock the chip to lets say 4Ghz? oh and do you guys think that a Hyper 212+ w/ Push/Pull would take the CPU to 4Ghz? Thanks! -Antsu
The NB will be fine on auto but you can bump it up to 2600mhz. The only thing you need to worry about is keeping the HT Link close to 2000mhz. I'm not so sure about 4ghz though, you'll just have to get it there slowly, run prime95 and keep a close check on your temps.
does the HT affect on CPU clock? Because if it doesn't the CPU is a nice overclocker... it did 4.2Ghz with 1.408Vcore and might go higher, didn't try to lower the vcore sense I was busy and my friend was freaking out that its gonna explode, lol. Its his first build
Oh and the temps maxed 52C on Blend for 1H
the temps look good, try to keep it around 55c max for stability
ht should stay close to stock, 2000
nb should default to 200, it can go higher, but will ramp up everything else, cpu/ht/nt/ram
1 - 5 of 5 Posts
