Help with Asus P5E problem
653 Views 10 Replies 6 Participants Last post by  mfb412
So, my in-game performance in some games has been truly abysmal, and lower than what i've seen from other users, then, i noticed THIS in CPU-z:
could this be why? and if so, how can i fix it?
1 - 11 of 11 Posts
Which slot did your put the GPU in? The blue slots run x16... The black ones only go x4 or x1.
EDIT: Wait, nvm wrong board.
Found this: http://www.techarp.com/showarticle.aspx?artno=522
Might help
ey, i had the same issue with my P5B deluxe. what i did was step up the pci-e frequency in the bios to 105 and everything works like a charm
Thanks for the hekp folks, +rep ot you both, i'll go to set the PCI freq
I reset it, disabled a ton of crap, reset CMOS, i tried everything, it still doesn't go to 16x, HELP
is your BIOS updated to the latest release?
1201 is the latest one for P5E. I would recommend flashing it to an earlier version just to see.
I have the latest version.
problem was solved by setting NB voltage to 1.65 and setting PCI-E freq to 115
Isn't 115MHz a bit high for PCI-E freq ??? You might damage the card
Might want to watch out doing that. You can corrupt your hardrive with high PCI-e frequencies.
Up to and including 115 is still safe for a P5E as far as i know from other users, and my HDD's seem fine
1 - 11 of 11 Posts
