help with cooler choice
303 Views 7 Replies 6 Participants Last post by  Dee.
well summer is almost here and my little cooler is starting to struggle , with my room at 74 degrees my cpu was running at 60 degrees celcius during occt so i need a cooler that will fit my board and case, i am considering the zerotherm 120, coolermaster v8 , zalman 9700 or tuniq tower , but i am leaning towards the CM v-8 any recommendations ?
1 - 8 of 8 Posts
The V8 is the best of the three you listed IMHO however the TRUE is still the best cooler available. I am going to be getting a V8 based on it looks and near the top performance, but I don't have heat issues if I did I would get a TRUE.
Just in case ThermalRight Ultra 120 Extreme
There are several versions based on material and processor type.
http://www.thermalright.com/new_a_pa...pu_cooler.html
TRUE. If you wanna stick the the 'egg, the V8
where can i get a TRUE at , what about the sunbeam core contact freezer
Where are you US, CA, EUR, Etc
cheapest I found with fan in the US
http://www.crazypc.com/products/ultr...775-50982.html
cheapest without fan
http://www.axiontech.com/prdt.php?item=57423
True or V8, Xig is not bad for price. The s1238
Originally Posted by sdla4ever View Post
True or V8, Xig is not bad for price. The s1283
Fixed
1 - 8 of 8 Posts
