I dont think your motherboard will support quad cores.
As for if that cpu is better, not unless you overclock it, for the purposes you are probably using it for the higher clocked dual core will probably serve you better.
* Socket: AM2 * Supports the following processors: o Athlon 64 X2 with Dual Core technology up to 5600+ (up to 89 watt) o Athlon 64 less than 4000+ o Sempron less than 4000+ |
