1 - 6 of 6 Posts
You best get one with the 8 pin connector!
BTW... I just received my NUUO550 today.. it has that connector!
In the manual it says you dont need the 8 pin connector and I have seen people use it without it, but I will limit your stable overclock.
DFIs are very power depandant with good OCing!
If that what you have for a PS go with it and see how it does.
there a quite a few people out there running them with the P-4 connector (4pin) instead of the EPS (8pin) connector. Try running yours and upgrade only if you face stability issues
1 - 6 of 6 Posts
