1 - 5 of 5 Posts
I'm trying to get motherboard monitor to work on my comp, but when i install it it asks me to pick a motherboard, and my mobo (DFI InfinitySLI) isnt on their, can anyone help?
go to DFIstreet and do a search there is a bunch of mother boards that they created the Data file for to replace in your MBM folder,,, then it will work no problem
,,,, just go take a browse,,,
you will probably have to manually set each sensor for each temperature. I had to do that on my last board. Use speedfan if you dont want to bother with that mess.
1 - 5 of 5 Posts
