1 - 2 of 2 Posts
i am doing a build for a friend, i have built over 10 pc,s in the last 2 yrs i put everything together and this is what happened,
1st). nothing , started with checking connections, and determined , case power switch is bad. used reset switch as a power switch until i go get a new 1, computer fires up
2nd) no video signal from gpu, removed gpu and tried the built in video, still no signal., changed ram, still the same ,should i try a different cpu or psu or just rma this mobo
gigabyte GA-MA78GM-S2HP
amd 5200x2 brisbane
crucail 2gb ddr2 800
nvidia 8600gts, cheapo case w/500watt psu?
Were the corresponding video options enabled in the BIOS when you were trying onboard and PCI-e?
1 - 2 of 2 Posts
