Help with DIGITAL OUT
314 Views 4 Replies 5 Participants Last post by  Mr Pink57
ok i have this card
http://www.amazon.com/Creative-SB009.../dp/B000XD47DU
and the problem is i can't connect an SPDIF toslink cable to the card to my Denon Receiver. The sound card however does have a digital out 3.5mm jack.
I found this:
http://www.amazon.com/Toslink-Female.../dp/B000FMM8TO
now here's the question. If i use that adapter and connect it to my 3.5mm digital out jack on that sound card can I then use a SPDIF toslink cable to my reciever and have sound?
rep for anyone with quick answer
~thanks
1 - 5 of 5 Posts
Originally Posted by razr7 View Post
ok i have this card
I found this:
~thanks
The adapter is only for mini-TOSlink, not any 3.5mm jack.
If your Denon Receiver does'nt have a Digital Input then you need a Digital to Analogue Converter (DAC).
You should be able to do that, yes. Although w/ a DAC.
no--you dont have live drive
I can't seem to find a pic of the connections part of that card. But on my old X-Fi I used a 3.5mm plug to a RCA adapter then plugged it in thru digital coax.
pink
1 - 5 of 5 Posts
