Help with evga 780i
514 Views 7 Replies 5 Participants Last post by  Moparman
Hi i have 2 bent pins on my evga 780i mobo. I was wondering is there a way to fix this without cause more damage to more pins?
1 - 8 of 8 Posts
Oh crap. This is way out of my league. I'm sorry. But hey, at least this is staying bumped to the top.
hard fix, i've heard a jeweler might be up to the task.
Have you tried running it with the CPU anyways? I had one motherboard with one or two bent pins, and it still run well for the months that I had it.
You can also try using an empty mechanical pencil tip to try and grab hold of the tip of the pins and straighten it up.
well i fixed it now i used a safety pins and a mechanical pencil. just dont have a cpu to test it with.
1 - 8 of 8 Posts
