1 - 5 of 5 Posts
bc i bought 3 140mm fans and had them sleeved and ended up returning the case for one that doesnt have 140mm holes. so its either pay 50 to have the new cases panel modded and wait 1 week or buy 3 of these for under 15 bucks
Retired Reviewer
Why buy those fan adapters? Make a template of your fan screw holes, center the temple on your 140mm fan frame, then drill new holes. All it will cost is a little time.
1 - 5 of 5 Posts
