1 - 5 of 5 Posts
Yes this might be a dumb question but i remember way back in 3rd grade, the only dumb question is the one you don't ask so here it goes...<br />
<br />
I'm upgrading and thinking about the DS3 with a new Core Duo. But i currently have a P4 3.4 and i noticed that the DS3 may support my current chip which is attractive to me but it only will support a P4 3.4 with 4 megs. So I tried SISoftware tool and can't find anything about the amount of L2 cache any help would be great. <br />
Thanks once agian!
Download <a href="http://www.cpuid.com/download/cpu-z-136.zip" target="_blank">CPU-z</a> and it will tell you.<br><a href="http://assets.overclock.net.s3.amazonaws.com/7/77/77acb50b_vbattach32511.bmp"><img src="http://www.overclock.net/image/id/617596/width/525/height/525/flags/LL"></a>
Is your P4 a socket 478 or 775 (does it have gold pins or gold contacts)?<br />
The DS3 is only for socket 775 CPUs, even ones with 2MB L2 cache.<br />
<br />
Edit: Here's the DS3 <a href="http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ClassValue=Motherboard&ProductID=2314&ProductName=GA-965P-DS3" target="_blank">CPU support list</a>.
Discussion Starter #4
It's a dell 4700 and i did not realize the P4 had two sockets...i just pulled the CPU last week and can't remember what it was!!! OK I'll have to check again and see. Thanks for your help. any thoughts on the DS3 with a 6600?
<tr>
<div>
Originally Posted by <strong>pixmap</strong>
</div>
<div style="font-style:italic">It's a dell 4700 and i did not realize the P4 had two sockets...i just pulled the CPU last week and can't remember what it was!!! OK I'll have to check again and see. Thanks for your help. any thoughts on the DS3 with a 6600?</div>
</td>
</tr>
</table>
</div>It's most likely a socket 775 CPU if you pulled it out of a Dell 4700. <br />
So, I'm pretty sure the CPU you pulled out is compatible with the DS3.
1 - 5 of 5 Posts
