help with gigabyte GA-K8NSC-939
1428 9
ok, i have a gigabyte GA-K8NSC-939 with a Venice 64 3000+, when i use the M. I. T. in the BIOS i cant seem to get anything on the overclock, i just keep getting the system hang message
"if system hangs on overclock go into BIOS options before overclock"
maybe im trying to do it too much?
ive never overclockeb before and im tryign to learn...
any suggestions?
maybe an actual program to use?
thanks
1 - 10 of 10 Posts
If I recall you have the "alt F1" for advanced options .
Please fill in your system specs in your Profile via the USER CP @ top of page
That will help us help you.
Did you read the message to yourself yet?
"IF system hangs on overclock go into BIOS options before overclock"
That means IF it hangs you can still get into your bios. Trust me, I have a gigabyte mobo too and it always says that.
Originally Posted by ogando_jose
Fishie the problem is that it reboots, and keeps on saying the same thing
Okay. Well the rebooting is a problem but I just wanted to point out that that message will always be there when you raise the FSB even by 1Mhz.
i have that exact same mobo, if it hangs just keep hitting delete as fast as u can can while its starting up/before it starts up. itll go into the bios eventually (works for me) make sure u have the f7 bios if ur ocing. the other one sux (f6 i think)
1 - 10 of 10 Posts
