1 - 7 of 7 Posts
I am trying to install windows xp home sp2 on my new system I just built. I have never installed any OS before. Where is a guide of installing xp on a new puter. I have an oem copy and dont even know what size partion to make for xp and which one to use to install xp in. Have a 200g harddrive. Any help or links to somewhere that I can find help would be great. THANKS
Just let it take care of it itself... It will automatically make the partition as large as it can. If you have nothing on the drive you need then delete all the current partitions and let it create a new one. Use NTFS -- don't use the Quick option because it'll skip disk checking!
I would suggest not using the entire disk for one big partition. Personally I belive that anything important should be stored in a partition that is not the C drive. This way, if the OS crashes and you're forced to reboot, you don't need to lose all of your data... in your case up to 200 gigs. Windows should have a 15 gig minimum, but 20 is better. On my 160 gig drive, I give it 60 gigs and then 2, 50 gig partitions for installer files, music, movies, etc. Formatting only kills my program installs.
For you, a 20-30 gig OS partition would be fine, and then you can divide up the rest however you want.
I will drop this into an FAQ too...
Installing Windows XP â€" I wrote this up for a friend, hope it helps.
Things to have ready :
•Your XP CD. Your XP CD key. Helpful tip : don’t have the CD KEY on the XP CD. When you need it the disk will be in the drive…
•Hardware manual â€" to make certain all the hardware is in right. Be certain the dip switches on the HD’s are set correctly to master/slave. The bios is set to boot from the correct source (CD to start â€" remember to switch to your preferred boot choice once done installing).
•Drivers for MB, video, audio, keyboard, mouse and anything else that plugs in.
•Internet passwords, installation instructions and your ISP phone #
•Anti-virus, malware (spyware doctor, search and destroy etc.) and firewall software ready with cd keys.
•Be disconnected from the Net.
New install :
•Since all your Hardware is set up properly…
•Drop in the CD and reboot.
•XP will start installing. If you need to install 3rd party RAID drivers you should be ready to interrupt the install once prompted about 30-45 seconds into the initial boot.
•You’ll reach a screen which allows you to partition your HD’s and select one for installation. Things to keep in mind :
oHaving you pagefile.sys which will be located in the root directory of the windows installation on a completely separate HD will increase performance. When Your OS requires information from an application that requires use of the pagefile.sys,you are forcing multiple data streams down a single channel. Partitioning the drive does not solve this.
oI like to partition like this heavy work area : low work area. This allows for high performance requirement software, like games, to be kept defragged at all times in the low work area. While HD space which is continually changed, added, deleted and accessed can be kept isolated. This allows your XP root drive and its pagefile.sys to function with an application, like a game, with high performace.
oIf you only have a single drive, I would partition a section for your OS with room for anything else you want there… always leave extra from other software and 15% more so defrag works well.
•Here you will also choose between FAT 32 vs. NTFS. You choose, here are some pointers with the better of the two:
oSecurity -> NTFS.
oCompatibility with earlier Windows > FAT 32.
oEfficiency -> NTFS.
oDurability -> NTFS.
•Format all the drives in the same file system, or you’ll face serious issues at a later date, and continue with the installation.
•Everything at this stage is self explanatory… just follow the screens. Skip the internet setup wizard, you will do that manually later.
•OK! Installed, it will be screaming about drivers… the choice is yours to let windows use its database of drivers or you use the factory ones provided with the hardware… I like to mix everything up!
•Get your MB/chipset drivers on. Install your video, audio and the rest now if you don’t need updated versions from the Net.
•Set up the internet, don’t get online yet.
•Install your anti-virus, firewall and all the anti-malware software.
•Get online.
•Update your anti-virus, firewall and all the anti-malware software.
•Update windows using… windows update.
•Update all the drivers.
•Install everything else.
Re-install (not repair)
•Same as above, but make certain you have everything you want backed up before you start. Like :
oEmail addresses, messages and accounts info.
oYour ‘My Documents’ folder.
Issues I have had in the past…
LILO â€" I remember this showing up on the screen when I turned on the computer â€" and only this. Black screen, white text. It refused to let me boot from XP. LILO is a Linux boot sector add-in. You need to make certain you have removed Linux, cleansed the boot sector or use a boot program when putting multiple OS’s on a system.
IDE cables wrong way round. Make certain that your Master drive has the proper IDE, SATA or whatever cables plugged into the right spots.
Reactions: ccwb333
Discussion Starter · #6 ·
Thanks some good info there. Mainly was trying to decide what partions I needed and how big to make the windows partion. Probably gonna wait and get more info. Still have my old rig until I get this one going.
I have 2 drives, with XP, all word processors and other apps on a fast SATA 80 GB drive. Then a 200GB partitioned 3 ways with 140GB for games and the other split equally for high volume traffic and multimedia. Works for me, but you got to find you balance.
1 - 7 of 7 Posts
