I'm probably not the best person to give advice because I haven't yet completed my loop just yet, but what I've read is that you need to make sure your loop is completely full. If you can still fit water in, keep putting in water. Once that's done, you'll need to pulse the system. As in, have the motor on the slowest speed, then pulse it up to the fastest, and keep doing this. While pulsing, try tilting your PC back and forth as well.
