Help with my Dell Mini 9
1186 Views 4 Replies 3 Participants Last post by  yellowtoblerone
Hello, I was looking around for some ram to put into my Dell Mini 9 that I recently purchased. I was thinking of buying this http://www.newegg.com/Product/Produc...82E16820104100 but its currently oos. Would the really low timings make a difference? (2GB of ram is the max supported by it)
512MB RAM
1.6 Ghz Intel Atom
8 GB SSD
Windows XP Home
Glossy 8.9 inch LED display (1024X600)
Also would the ram be the reason why videos play well for 10-15 sec. then freeze for half a second then another 10-15 sec followed by another half a second freeze? The videos are avi files with a resolution of 1250x720 (not at home so I don't remember the exact resolution but that's about what I remember).
Forgot to mention I did install CCCP and it doesn't seem to help with the video freezes, guess it might just be the resolution is too high for the mini?
If you guys recommend any other changes I'm open to them, I mostly use this at college to surf the web, watch some videos online, and to work on assignments between classes.
1 - 5 of 5 Posts
Are those HD videos? If they are high-bitrate HD videos, the onboard graphics of netbooks just isn't capable enough to smoothly decode the video and thus gives you shuttering playback.
One suggestion: try using VLC Media Player instead.
As for the RAM, you won't really notice much of a difference between 5-5-5 timing RAM and 3-3-3 timing RAM in a netbook. The Atom CPU will still remain the bottleneck as it's not a performance CPU (like that of a C2D).
The increased RAM will help in video playback and in multitasking if you're already reaching the limit on your Mini 9.
Thanks for the quick reply, yes they are HD videos, and I do currently use VLC.
A friend told me to try zoom player right after my op and I did, what happens now is the video is smooth no freezing!
but the audio after about 5 mins starts to go out of sync
Thanks you your suggestion on the ram which one of these would you recommend?
http://www.newegg.com/Product/Produc...rder=BESTMATCH
+rep
I'd go with the first Kingston one. It's cheap, reliable, and has free shipping. Technically, the Mini 9 uses DDR2 533 RAM, but the 667 should have no problem running at a slower effective bus speed.
The 945GSE chipset just isn't made to handle HD videos since there is no hardware encoder/decoder and everything is reliant on whatever software encoder that comes with your software media player. This in turn off loads the entire load to the CPU. Since the CPU is already playing your video and audio, it now has to do triple duty and also decode the HD stream. That's just too much for the Atom to smoothly manage.
I've bought a mini 12. I heard that the Dell mini 12 don't take sodimm as memory's pre built onto board. True false, or maybe diff from mini 10/9
1 - 5 of 5 Posts
