1 - 19 of 19 Posts
since i needed a new mobo for my other pc i better make a new 1 do i can improfe my cpu aswel
so here are what i think to buy (dont know so much about it but i try to learn plz help me)
motherboard
Asus P8P67 Deluxe DDR3 Socket 1155 Intel® P67 224.90euro
cpu
Intel Core I7 2600K 32NM 3.4GHZ 8MB LGA 1155 Boxed 309.90euro
Corsair H50 Hydro Series CPU Cooler 74.99euro
ram
4GB Kit (2 x 2GB) 1600Mhz DDR3 9-9-9-24 PATRIOT Sector 5 Gaming Series 69.99euro
case
Nzxt Phantom White 139.90euro
gpu
Asus enGTX470/g/2DI/1280MD5 1280MB DDR5 PCI Express Nforce GTX470 (i already have) 239.90euro
ssd
OCZ OCZSSD2-2VTX80G 80GB Vertex 2 S-ATA II MLC 119euro
corsair hx650w(i have already) 119.90euro
are all parts compatible? and good for overclocking?
did i forget somthing?
prethanks for your help
editted
Inb4gosandybridge
You might as well go 2600K if you're building a new pc
sandy bridge 2500K or 2600K the "K" is a unlocked model for overclocking.
and buy a motherboard that suits you for it.
It runs faster and it draw less watt than a i7 950 and overclocks better.
Originally Posted by andrewmchugh;12006902
Where abouts are you from (£/$) and whats the max budget and cost of the line up in the initial post?
im from belgium and max that i wanne spend is like +-1400
i edit with prices now 1sec
ps the shop where i was planning to buy it is www.tones.be its dutch but its easer for me to not run too 100stores xD
but they have a lot(i think)
if you want a tri chan ram setup u will need a board like mine x58 - but its i7 1366 only. if you want to stick with the 1155 then u need dual channel memory.
My understanding is DDR3 tri channel is for the 12xx pin intel (3x sticks for tri channel) But 2x2 sticks of DDR3 works fine in 1156/1155 and am3
Discussion Starter · #14 ·
Originally Posted by andrewmchugh;12006988
if you get the mb and cpu i said the computer will go like a rocket and oc well. im not a fan on 1155/6
thats what i wanted to do first but them they said the 2600k was better to oc
i first had the 950 in my list
so know i dont know enymore
motherboard
Asus P8P67 EVO DDR3 Socket 1155 Intel® P67 187.90euro
cpu
ram
Corsair CMX6GX3M3A1600C9 6GB KIT (3X2GB) 1600MHZ DDR3 XMS Triple Channel 129.90euro
case
gpu
ssd
editted
Your ram will have compatibility issue with the motherboard. It is because it is for triple channel memory like LGA 1366 eg.i7 900 series above or Xeon 3500 series and above.
So I suggest you to get anything with dual channel and not more than 1.65volts.
For graphic card, I suggest you to get GTX570. It is newer and it ran quieter and less heat than the previous generations. It is faster too.
Are you going to use SSD for the main storage? Why not invest a few more on hard disk so that you can store your photos and games.
Discussion Starter · #16 ·
i cant change grapics cards i have them already and yea the ram doesnt fit xD
but what should i take
P6X58D-e DDR3 Socket I7 with i7 950 and that ram from my list
or the mobo from my list with the 2600k
2600k bulldozer is faster clock for clock and overclocks better. If I had a i7 i'd ot upgrade but if I was buidlng new i'd go 1155
Discussion Starter · #18 ·
am i wrong or not?
if been searching on the net for what is best on the 2600k and what for 950
so they said that 2600 is faster but 950 is better for games(because of better mobos) is that right?
because if thats right i go for the i7 950 because i mostly game on my pc
and the 950 is fast to when its overclockt i think
1 - 19 of 19 Posts
