help with OC
231 Views 1 Reply 2 Participants Last post by  waverider599
When I run prime95 with large data (the middle option) at about 14 hrs everything is good visually i can see number fluctuating but as soon as i go to move the mouse and open an app everything locks up, does that sound like i need to up the voltage to the QPI or Vcore or is it imposable to tell?
1 - 2 of 2 Posts
What voltage are you at now? Try upping the voltage and see if that makes a difference. If you have to up it too much in order to get the clock you may have to lower the speed (depending on the heat the voltage generates.)
1 - 2 of 2 Posts
