by getting better ram like 4200 because your ram maxes out at 200
Originally Posted by RubberDucky by getting better ram like 4200 because your ram maxes out at 200 |
Originally Posted by z_one According to this webpage (from Asus` website) you have an adjustable FSB/DDR ratio. Are you sure your settings for this are not on "Auto" ? This might be the reason why your mobo is changing the divider. You should try to manually adjust it. Look at page 4-18 of your manual "DRAM Frequency". Also try to increase the CAS timing from 2.5 to 3 and try again. |
