1 - 8 of 8 Posts
I want to overclock my bro's pc but i need alot of help. Its a AMD Sempron, 1600 mhz (8 x 200) 2600+ processor, ASRock K8Upgrade-NF3 MB, 512 MB Kingston valueRAM, NVidia Geforce FX 5200 (128MB). Can anyone help me with settings for this. Its on stock cooling and temps are at 63-68c idle. The fan speed however is 790 RPM, is that normal?
· Premium Member
All of these suggestions about spending money on cooling cost more than what that rig is worth. Tops I'd spend $25 on cooling and if thats not going to help I'd save till I can buy a new rig. I'd say to try to improve airflow, possibly some cable management if you have any extra fans lying around I'd use them. Maybe re-seat the factory HSF and add some AS5.
I'm currently using my backup rig while my sig rig is under construction. Its a amd64 3000+ socket 754. I have it in a $20 dynex case and I added a 120mm fan in the 5.25" bays. I also had bought one of those artic freezer pro when they were under $20. Idle temp right now with 75°F ambient is at 30°c
1 - 8 of 8 Posts
