1 - 12 of 12 Posts
Hello guys!
I'm trying to overclock my current CPU. Since its a black Edition I only need to turn up the multiplier and adjust the voltage right?
Well I'm kind of stuck at 3.6/7 Ghz because I don't know what the voltage in my bios is named. I'm getting a bsod at 3.8 after some time in windows.
Here are some pics:
What do I need to do next?
Thanks!
System: http://www.sysprofile.de/id179768
You change the CPU voltage control setting to something else, but that default VCore (1.4750V) is actually pretty high.
What kind of temps are you getting during stress tests?
Turn voltage to 1.5 and go as high as you can. Your temps look good
Should be able to get 3.8-4GHz on 1.5v.
You may want to try putting CPU PLL voltage at 2.62v also.
Don't forget that you are going to want to bump NB to around 2.8GHz, which will take anywhere from 1.3-1.4v
Again, keep an eye on temps.
Your BIOS looks identical to mine, so I could post up my 4GHz settings for you later. (at work now)
Discussion Starter · #8 ·
It runs at 3.8 Ghz stable now but the three temps (I guess nb and mainboard) are quite high for a 24/7 OC aren't they?
Why is the CPU voltage at 1.344 in the OS when I turned it up to 1.5 in the Bios like you told me to do.
Temps are within spec.... not sure if you are turning up the right voltage or not....
I can tell you right now though, if the CPU is running P95, even short term at 3.8GHz with that low of voltage, then you have one hell of a chip on your hands.
You should be able to lock down 4-4.2GHz on that thing with 1.45-15v. However, your temps will be too high, so without some better air cooling (possibly try a re-app on TIM), or some mid-grade water cooling, you may be stuck at that voltage.
I'd be concerned you are sending 1.5v to something other than the CPU with that 1.344 reporting though.....
Discussion Starter · #11 ·
I turned up the cpu voltage control by accident but just by 0.025v, just realized that ^^ i thought i turned it to 1.5 because i added the +0.025 to The 1.475v vcore underneath in my mind.. So how can i turn up the vcore?
And why did it run stable
Why is the mainboard so hot when the cpu is so cool?
1 - 12 of 12 Posts
