21 - 40 of 55 Posts
5950x, x570 Xtreme, Evga Ultra 3090, G.Skill 3800 cl14, NZXT z73 cooler, Lian li XL case
Discussion Starter · #21 ·
im gonna see if I can accomplish this lol
vedrò se riesco a realizzare questo lol
[/CITAZIONE]
Caro Amico, volevo solo farti capire che è molto importante che la CPU riesca a spingere bene su IF, e con ram come quelle consigliate e ottima dissipazione, il 5950x è un piacere. A poco a poco la tua conoscenza e fiducia sulla tua offerta avanza e sono sicuro che migliorerai ovviamente, nessuno nasce imparato.
Discussion Starter · #24 ·
Turn PBO off.
Set all Core to 4.5GHz. Boot up and run Cinebench R23. Monitor temps and SV12 Voltage. Perhaps run a timespy benchmark and see if you get a flat line on CPU frequency which you should.
I can leave my ram timings as they are correct? Im at 3733 cl14, or is XMP a must, I was having a hard time getting it to hit XMP @3800 cl14
Adopted 4.75Ghz on all core. 1.330V which sees sustained under load at 1.269V for all 12 cores. 65C max.
Flat line and higher score due to the CPU test in this benchmark benefitting from an all core.
2518166
Reactions: munch06
If its stable yes.
Dont forget to adopt 50% of the infinity fabric relative to your ram frequency. 3600MHz ram = 1800mHz infinity etc...
Reactions: 72kos and munch06
Posso lasciare i tempi della mia ram in quanto sono corretti? Sono a 3733 cl14, o XMP è un must, ho avuto difficoltà a raggiungere XMP @ 3800 cl14
[/CITAZIONE][/CITAZ
Se hai problemi a ottenere IF1900 e la CPU non ne vuole sapere, anche 3733 Mhz va bene IONE]
There's a newer bench in latest update, CPU Profile, and I think it's more suitable for CPU testing alone.
Reactions: munch06
Discussion Starter · #29 ·
If its stable yes.
weird I can seem to set my CPU clock ratio to 4.5, when I try to type it in it jus goes to 8.00
Discussion Starter · #30 ·
2518303
LOL. Type in 45. Not 4.5 hahaha.
Any reason you increased VCORE SOC ? It should be between 1.100 and 1.200V
Reactions: munch06
lol oh dam :LOL:, i get nervous when doing OC lol, so scared im gonna mess something up bad
The worst thing that will happen is say if you enter 50 in the CPU ratio, your PC might not boot, and bios will reset itself and you start again.
Obviously be careful with voltages of course and change parameters that other people have tested on.
Reactions: munch06
Plz don't tell me it took you over 24 hours to go into the BIOS to enter an all core ratio ?
Discussion Starter · #35 ·
hahaaa, wasnt a full 24hrs it was late last night :LOL:, I wasnt sure if I was entering it in the right place when it showed 8.0 so I stopped LOL, im gonna try it soon tho 😁
  • 45 in the CPU clock ratio
  • 1.30-1.33v in the CPU Vcore
  • PBO off
  • mem/fabric matching at half the mem frequency (3733 = 1867) " 1:1 "
  • PBO off
I'd say that's a good starting point. 3733 = 1867 which equals 2 to 1.
You'll be idling around 1.3ish volts, but under load, your CPU should drop in voltage to around 1.250 or less under load for all cores. Use HWinfo to monitor temps and voltage.
Reactions: munch06
Discussion Starter · #37 ·
ohhh ok, I thought if mem and fabric clock are both at 1867 thats means 1:1, isnt 1:1 better then 2:1?
3733Ram and 3733 Infinity fabric would be 1:1 ? Correct me if Im wrong.
Discussion Starter · #39 ·
hmm k I think im kina understanding now lol, I got alot to learn still 😁, alright im gonna:cool: give this a go soon
What cooling do you have for that 5950X ?
21 - 40 of 55 Posts
