41 - 55 of 55 Posts
Iconoclast
You shouldn't need more than 1.1 vSoC or so for 1866FCLK.
3733Ram and 3733 Infinity fabric would be 1:1 ? Correct me if Im wrong.
DDR4-3733, 3733MT/s, etc, is ~1866.6MHz. A 1:1:1 FCLK:UCLK:MCLK ratio would be 1866MHz across all three, which implies 3733MT/s memory, because DDR implies two transfers per I/O clock cycle.
Actual clock I/O clock speeds are what matters for syncronizing clocks, not the transfers per clock.
Reactions: munch06 and HeLeX63
5950x, x570 Xtreme, Evga Ultra 3090, G.Skill 3800 cl14, NZXT z73 cooler, Lian li XL case
Discussion Starter · #44 ·
holy **** I jus got time to try today and it instantly blue screened didnt even load, the BSOD popped up right after bios and said "PC didnt load properly" and to restart
Discussion Starter · #45 ·
ok ill try to bring it down, I actually forgot when I was trying to hit 3733 cl14-14-14-32, I did hit that but I tighten things too tight and was unstable and then forgot all my timings I entered
What were your final settings ? Did you set correct infinity fabric ? What voltage did you apply to CPU.
Those timings seem really really tight. I reckon your Ram is unstable. Loosen them up.
Discussion Starter · #48 ·
cpu ratio 45.0, cvore 1.30, PBO disabled, my timing are now whats in the pic, I jus left everything on Auto for now
2518383
Discussion Starter · #49 ·
wonder what im doing wrong🤔
You have 64GB of Ram, populating all four slots and with those tight timings on a pretty high frequency.
Are those timings manually entered or default XMP ???
Discussion Starter · #51 ·
manually, XMP is 3800 cl14-16-16-36, but on xmp I can only hit 3733
Dial it down to 3600MHz with CL 14-16-16-36 with Infinity Fabric to 1800Mhz
Reactions: munch06
Discussion Starter · #53 ·
Dam that sux lol, shouldn’t I be able to run this at these timings?
For the sake of trying to know if your CPU is unstable or your ram is. See if u can boot into windows on a lower Ram frequency for now.
Reactions: munch06
chissà cosa sto sbagliando🤔
[/CITAZIONE]
[/CITAZIONE]
secondo me hai una tensione Vsoc esagerata per quella frequenza, di solito la tensione vsoc viene aumentata oltre 1.125V visto che si sale di frequenza, considerando che da ram 3800 cl 14 (come la mia) sei sceso a 3733mhz io proporrei di no superare 1, 125- max 1,14V
41 - 55 of 55 Posts
