I have a clawhammer FX55, it is cooled with a Zalman CPNS9500LED, it idles at 32degrees celcius, full loads always stay under 50degrees celcuis, i tryed to up the multi to 14 to get 2.8Ghz, it wouldnt load windows, so i upped to the voltage using the MSI motherboard setting, and increased it by 3.3%, it booted into windows but restarted straight away, i then increased it to 5.5% increase and its now in windows but its not stable on aquamark. I could try to add 8% more voltage bus isnt this to much just for a 200Mhz overclock.
