Ok I really need help with overclocking all together, ram, cpu, etc. I already set my cpu from 2.66 to 3.04 but i cant set my voltage higher because my pc beeps. Can someone please look at my cpu-z info and see what i can change to make my pc run faster and more stable. Thank you
CPUID Output
Number of CPUs 1
APIC ID 0
Name Intel Pentium 4
Code name Northwood
Specification Intel(R) Pentium(R) 4 CPU 2.66GHz
Family/Model/Stepping F27
Extended Family/Model 0/0
Brand ID 9
Package mPGA-478
Core Stepping C1
Technology 0.13µ
Instructions Sets MMX, SSE, SSE2
Clock Speed 3039.8 MHz
Clock multiplier x20.0
Front Side Bus Frequency 152.0 MHz
Bus Speed 608.0 MHz
L1 Data Cache 8 KBytes, 4-way set associative, 64 Bytes line size
L1 Trace Cache 12 Kµops, 8-way set associative
L2 Cache 512 KBytes, 8-way set associative, 64 Bytes line size
L2 Speed 3039.8 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 256 bits
Chipset
Northbridge SiS SiS648 rev. 3
Southbridge SiS 963 rev. 25
Graphic Interface AGP
AGP Revision 3.0
AGP Transfert Rate 4x
AGP SBA supported, enabled
AGP Aperture 128 MBytes
Memory Type DDR
Memory Size 1024 MBytes
CAS# 3.0
RAS# to CAS# 4
RAS# Precharge 4
Cycle Time (tRAS) 6
Bank Cycle Time (tRC) 11
Memory SPD
DIMM #2
General
Memory type DDR-SDRAM
Manufacturer (ID) Samsung (CE00000000000000)
Size 864 MBytes
Max bandwidth PC2100 (133 MHz)
Part number M3 68L6423BT1-CB0
Manufacturing date Week 00/Year 00
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
Frequency (MHz) 100 133
CAS# 2.0 2.5
RAS# to CAS# delay 4 5
RAS# Precharge 2 3
TRAS# 20 26
DIMM #3
General
Manufacturer (ID) (FFFFFFFFFFFFFFFF)
Size 512 MBytes
Max bandwidth PC3200 (200 MHz)
Part number
Serial number FFFFFFFF
Manufacturing date Week 255/Year 255
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
Frequency (MHz) 0 166 200
CAS# 2.0 2.5 3.0
RAS# to CAS# delay 0 4 4
RAS# Precharge 0 4 4
TRAS# 0 8 9
DMI BIOS
BIOS #1
vendor Award Software, Inc.
version ASUS P4S8X-X ACPI BIOS Revision 1005 Beta 001
date 10/31/2003
DMI System Information
System #1
manufacturer System Manufacturer
product System Name
version System Version
serial SYS-1234567890
UUID 00000000-00000000-00000000-00000000
DMI Baseboard
Baseboard #1
vendor ASUSTeK Computer INC.
model P4S8X-X
revision REV 1.xx
serial xxxxxxxxxxx
DMI Processor
CPU #1
manufacturer GenuineIntel
model Intel(R) Pentium(R) 4
clock speed 3039.0MHz
FSB speed 152.0MHz
multiplier 20.0x
DMI Memory Controller
Memory Controller #1
correction unknown
Max module size 1024MBytes
DMI Memory Module
Memory Module #1
designation DIMM 1
Memory Module #2
designation DIMM 2
size 512MBytes (double bank)
Memory Module #3
designation DIMM 3
DMI Physical Memory Array
Physical Memory Array #1
location Motherboard
usage System Memory
correction None
max capacity 1024MBytes
max# of devices 3
DMI Memory Device
Memory Device #1
designation DIMM 1
format DIMM
type DRAM
Memory Device #2
designation DIMM 2
format DIMM
type DRAM
total width 64bits
data width 64bits
size 512MBytes
Memory Device #3
designation DIMM 3
format DIMM
type DRAM
total width 64bits
data width 64bits
size 512MBytes
Software
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX Version 9.0c
CPUID Output
Number of CPUs 1
APIC ID 0
Code name Northwood
Brand ID 9
Package mPGA-478
Core Stepping C1
Technology 0.13µ
Bus Speed 608.0 MHz
L2 Location On Chip
Chipset
AGP Revision 3.0
Memory Type DDR
CAS# 3.0
RAS# to CAS# 4
RAS# Precharge 4
Cycle Time (tRAS) 6
Memory SPD
DIMM #2
General
Size 864 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
CAS# 2.0 2.5
RAS# Precharge 2 3
TRAS# 20 26
DIMM #3
General
Size 512 MBytes
Part number
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Timings table
CAS# 2.0 2.5 3.0
TRAS# 0 8 9
DMI BIOS
BIOS #1
date 10/31/2003
System #1
product System Name
DMI Baseboard
Baseboard #1
model P4S8X-X
revision REV 1.xx
serial xxxxxxxxxxx
DMI Processor
CPU #1
FSB speed 152.0MHz
multiplier 20.0x
correction unknown
DMI Memory Module
Memory Module #1
designation DIMM 1
Memory Module #2
designation DIMM 2
Memory Module #3
designation DIMM 3
usage System Memory
correction None
max# of devices 3
DMI Memory Device
Memory Device #1
designation DIMM 1
format DIMM
type DRAM
Memory Device #2
designation DIMM 2
format DIMM
type DRAM
total width 64bits
data width 64bits
size 512MBytes
Memory Device #3
designation DIMM 3
format DIMM
type DRAM
total width 64bits
data width 64bits
size 512MBytes
Software
