1 - 13 of 13 Posts
im stuck here.i have a 2.8 oc to 3.28..cpu external fqz 215 .hyper threading enabled.i didnt touch the dram fqz i left it on auto?options are 266,320,400mhz.i have pc3200 kingston value ram 2gs.i uped the voltage on the cpu to 1.625 and ddr 2.55 agp 1.5..it runs stable and cool 23c/77f idle.my bench mark for 3dmark05 was 4989 the most i got was 5050.i think this sucks?my gpu is a bfg 6800 256mg card.so im stuck here! any suggestions on what to do with the memory fqz?.more system specs lok at my profile.please thanmk you.i have other memory timings but i dont know what to do with them?
You can push you processor more, expecially with those low temps. I had a P4 2.4Ghz that I got up to 3.6Ghz on air cooling! You don't need to mess with your memory frequency. It will adjust to your BIOS automatically. You may want to play with the timing, but I wouldn't worry about it.
Eithre push the processor a little more, or start looking for a new one... Have you OCed your video card?
the only option i have for the gpu is the agp/pci fqz which is set at 66.66/33.33.ill go alittle more with the cpu and ill get back to you
Your temps look good, so definitely increase the FSB a little. Keep in mind though that your Kingston ValueRam is more than likely topped out at ~215, so it might be time to try a divider. Set the ram frequency in bios to the 320 (or 333), this should be like a 4:5 RAM:CPU divider.
You can't overclock a GPU through the BIOS. Seeing as you're running nVidia, I'd reccomend trying coolbits2 in order to overclock. Or, you could mod your GPU BIOS, but that's a bit more advanced and harder to work with.
Discussion Starter #7
i just downloaded riva tuner v2.0 rc15.8 where to start?Set the ram frequency in bios to the 320 (or 333), this should be like a 4:5 RAM:CPU divider.----i dont know where that is 333 is in mhz right i have an option for that 266 333 and 400 so you want me to use the 333mhz?
Discussion Starter #9
i just loaded ut up at 320 mhz no problems.more FSB at 1:1 i dont have that option. i have a cpu external fregeuncy option is 100 to 400 stock leaves me at 200 so i set it to 214 and i got 3.28 mhz.i have no ideal what the fsb is its not listed on this board. as for ram timings the option is this.. dram idle timer 0t 8t 16t 64t and auto.mine is on auto..next option is dram refresh rate opt is 15.6sec 7.8sec 64u 64t? mine is on auto.theres another option dram timing by spd mine is enabled if i disable i get 4 more options.??
Leave the timings to SPD.
FSB at 1:1 may not be an option in your bios, but basically as long as the ram is running the same fsb as the cpu, then you're runnin 1:1.
1 - 13 of 13 Posts
