Help with Q6600 OC with new RAM...
199 Views 2 Replies 2 Participants Last post by  Anth0789
Now with the the new ram I can't seem to get a good OC out of my Q6600. It looks like my ram is running at 800mhz instead of 1066mhz @ 5-5-5-15 timings. What do you guys think I should do to get a decent OC out my new ram? I think im able to get it at 3.4Ghz stable but the ram is running around 950mhz.
1 - 3 of 3 Posts
You could lower the multi and raise the FSB. That's the easiest method. Or use the 378FSB (if that's where you are at) and try the memory multi x3.
378 x 3 = 1134mhz though, so I'm not sure if your set can handle that. If you don't have the PI 8500's, 1134mhz might be possible.
Got it 3.4Ghz stable now...
1 - 3 of 3 Posts
