1 - 4 of 4 Posts
Right now I have my timing set at 3-3-3-10, 2.75v, 7/7 ratio, fsb at 228. Now how can I lower my divider so that I can up my fsb to maybe reach 232-238?:withstupi
7/7 is a 1:1 divider on your ram. Not sure exactly how the rest of them go on your MOBO, but it should be either 5/7 or 4/7. That should get you to where you want.
cause your system is unstable, and most likely its not your video card....You should never overclock your system if you aren't familiar with the settings...read some overclocking guides before you melt your system
1 - 4 of 4 Posts
