1 - 12 of 12 Posts
im trying to help my bro with his sempron 2600 computer my uncle gave him<br />
by incresing the fsb we get 1.98ghz till the ram starts to give in<br />
then i found out i can do the pencil trick to it, tried it and it dident work<br />
ive redone it about 5 times now and it still wont take<br />
its a via kt333 chipset so it should work.<br />
ive done the pencil trick before with my athlon 900 and 1200 both worked flawlessly (till i poped them <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick out tounge caps" class="inlineimg" />) in a asus mobo with a voltmod<br />
i just cant see why this aint working
<tr>
</td>
</tr>
</table>
</div>That's the problem right there...
A pencil trick if possible would need to be performed neatly, if possible at all.
Your best bet is to purchase a used "ABIT NF7-S version 2" motherboard<br />
that has a great bios to give you oc'n capabilities yur looking for.<br />
Used prices can be near $25. or less I suppose.
When doing the pencil trick sometimes you need a higher grade of pencil than at other times.. Go to a print shop or drafting supply shop and get a .3 mm pencil with H fills..... ;-D I got tired of pencil mods on 462's and now only use super glue and silver circuit writer.
Discussion Starter #6
the pencil trick wont work on NF chipsets, and i dont want to spend money on this computer other than the ram, and it might be the pencil!<br />
im using a papermate HB2, i got a lead pencil i can try, and alot of 40/60 solder
<tr>
<div>
Originally Posted by <strong>redhat_ownage</strong>
</div>
<div style="font-style:italic">the pencil trick wont work on NF chipsets, and i dont want to spend money on this computer other than the ram, and it might be the pencil!<br />
im using a papermate HB2, i got a lead pencil i can try, and alot of 40/60 solder</div>
</td>
</tr>
</table>
</div>If you have any DDR400 the NF2 mobo will support it vs. PC2100/PC2700.<br />
Big diff
Not all Socket A work with the pencil trick.
Discussion Starter #9
GOT IT!!!<br />
mobo detected: unknown cpu type 2600+<br />
dling cpu MSR right now<br />
<br />
ill post results
<img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /> <br />
<br />
persistance pays off well, gL
You could still find a used nf2 board for really cheap, I recommend the An7
Discussion Starter #12
damn now i got a really slow A64 chip<br />
i can only change the multi down!<br />
its late im going to sleep ill try agian tomarrow<br />
more google searches <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick out tounge caps" class="inlineimg" />
1 - 12 of 12 Posts
