Help with Server 2008 & file sharing
723 Views 7 Replies 4 Participants Last post by  Manyak
Hi guys I've been having some file sharing issues with my server.
Recently I upgraded my server os from 2003 to 2008. Everything works fine but the thing is, I cant modify existing files. For example:
Ive created 'userA' account andbelongs to administrator group.
Now I shared my drive using the Advance sharing.
Ive set the drive permission with userA as full control.
So now i can create/put file to the shared drive with no problems.
Reading or opening any existing files also works fine.
However, when I tried to modify the existing files, i'd get the permission/ write protected error.
So any ideas? TIA
1 - 8 of 8 Posts
Double-check the NTFS permissions for the folder and make sure UserA has "Modify" access to the specified folder...?
Originally Posted by sidewinder69
That did the trick. Thanks a lot
Just a reminder that with Windows file sharing "Most-restrictive" is the effective permission. That is, the most-restrictive setting for a particular user / group in both Sharing and NTFS security settings is the effective permission.
Normally, the industry-standard way of sharing folders is to do wide-open "Sharing" permissions, either "Everyone" or "Domain Users", and then lock it down using the NTFS permissions. This is because the NTFS permissions are more granular and offer a greater degree of control. For example, with NTFS permissions, a user / group can create new files in a folder, but they can't modify existing files.
Anyways, just a reminder. Used to drive me nuts back when I was playing with Windows 2000...
hey didnt know it can be done in that manner. thanks for the heads up. is the NTFS security a new feature in 2008 cos i wasnt aware of it in 2003?
It's been there since Windows NT 3.51
heh, we still use 3.51 at my work
Not surprising. Most businesses go by the rule of "if it ain't broke, don't fix it".
1 - 8 of 8 Posts
