1 - 6 of 6 Posts
I think my 960t is completely locked as quad unless I have done something wrong.
memory timings I never touched put them at AUTO, it's Vengeance XMS3 2x4GB so in total 8GB
I tried disabling 5th or 6th core and save bios, screen just goes dark and fans blow really hard.
Once power off on power on pc it says Unleashind mode failed.
163
Originally Posted by pc-illiterate View Post
cores 5 and 6 (core4 n core5) arent necessarily the locked cores. any 2 of the 6 can be locked.
I thought the motherboard knows what 4 cores is enabled?
So then I need to disable #1, if fail # 2 if fail #3 if fail # 4?
I already tested disaple #5 or #6
try these . . .
CPU Voltage: AUTO
DRAM Freq: AUTO
COOL & QUIET: Disabled
ACC: Auto OR Enable
CPU cores: Auto
Turn on LLC if available
1 - 6 of 6 Posts
