Hi guys,
I've been debating between two things I want to do. I got to save the money for an extra zotac gtx480 amp. The question is should I do it? Is it worth it? I've done tons of research and I found all the benchmarks, pro's and con's.
So, would you guys run a a gtx480 sli set up or would you do something else with the moneyz?
On the other hand, I was thinking that I could also custom build a liquid cooling system(GPU, CPU, MOBO)
Whatcha guys think?
Thanks!
Ariel
Whatcha guys think?
Thanks!
Ariel
