1 - 4 of 4 Posts
Hey all ...
I had my Galaxy S2 connected to my pc earlier today to transfer some movies to my phone ... worked great ... but now I connect my phone to my pc and my pc doesn't show my phone or even pick it up ... when I go into usb setting and say connect it tells me the cable is already connected ...
How can I fix this ??
All information greatly appreciated ...
Kind Regards.
First off:
Is it rooted? What carrier do you have? What OS version?
otherwise there are a lot of possibilities, and the only general advice I can give you is to turn off your PC, and phone, then turn both back on and connect the phone again.
My phone is not rooted to my knowledge ...
I am with the carrier "Vodacom" using OS 2.3.4 ... ... Since this not connecting problem started I am having another issue where the application Samsung Keypad reaches 4000kb of data and then force closes which causes me 2 have to clear the date and force close all apps that use the keypad before I can type again
1 - 4 of 4 Posts
