1 - 3 of 3 Posts
All my PCI slots are full, I have 4 hdds. I upgraded to a large hdd to eliminate 3. I also eliminated several PCI cards..4 to de exact. My question is, will my temps go down after the removal of all these items?
it all depends on what kind of Pci cards and Hdd u were using.
removing the hdds will help bring down temp a little bit
but i dont think pci cards has any affect on temp buz they dont make that much heat( except grahpic card)
odds are removing PCI cards will just increase air flow in the case and maybey give your video card more room to breathe... the HDD's generate alot of heat though so that will help case temps go down... but other than the increased airflow your CPU temps will stay about the same.
1 - 3 of 3 Posts
