2 things, first the ASUS 600i series do not OC quads very well, so dont expect much above 3.oGHz. And second, the NVIDIA 600i series does have FSB hole issues. There are some frequencies the boards just wont run at. This is due to the Chipset strap. There is more info in the 680i link below in my sig. So basically when you think you have hit a wall, try jumping 40-60 QDR to jump past the dead spot.
Can you list the voltages you have tried?
I would think you need about (just a guess on vcore since every CPU is different) 1.35v vcore, which is a generous estimate since many can run 3.0GHz at 1.30v vcore. But you can lower once you get it stable. Then set the NB to 1.35v - 1.4v and the FSB termination voltage (VTT) to 1.35v. See if that gets you anywhere with a 1333QDR.
