Originally Posted by Yangas
What I meant by my sound stopped working is that my headphones aren't producing and sound I can see the mic bar move okay, but I cant hear anything on youtube or when I talk on mic.
Hmn... if the output volume is up and unmuted, try the output tab within sound preferences. Make sure the right device is selected, and the correct connector is chosen. Really, Karmic 9.10 sound preferences are really pitiful compared to older versions, there's not much you can do in there. Try selecting and changing things within the sound preferences menu.
Also a heads up, Wine programs can eliminate sound. Running steam and other programs in Wine do sometimes make it so there is no sound output. If you've got steam running, turn it off, or any other program running in Wine, shut them all down. However, I believe in Karmic they fixed this issue.
I am at a loss, generally sound should work. Try restarting the computer, and if that doesn't work, I give up. If your headphone has a seperate volume control, this might be the time to turn it up too.
