1 - 5 of 5 Posts
Originally Posted by SenorPancake
I recently bought and put in an arctic cooler ATI silencer 1. For some reason I'm now getting major texture corruption on anything that remotely makes the card work. Any advice?
What kind of Heatsink thermal compound did you put on??
Edit: You really need to fill in your system profil, so we can help you better.
I used the silicone paste that came with it.
You wouldn't happen to have any AS5 laying around do you?? The stock paste that comes with it really isn't very good, but should get you by. It sounds a lot like you didn't install the H/S correctly or it didn't seat very well causing the GPU to heat up. Try re-seating the H/S and see if it helps.
1 - 5 of 5 Posts
