here is an idea and i need help fast
881 Views 10 Replies 6 Participants Last post by  mr soft
ok so for my sig rig mods i am thinking about painting the heat sink cover black what do you guys think? i saw bill owen do it on one of his mods and well i wamt to do it too. and well any advice on how to do it and will it affect temperatures? pros cons anyone?
1 - 11 of 11 Posts
i dont think painting the heatsink would be good. i would think that your temps would go up because of this.
not the heat sink the plastic cover it has on top
what plastic cover. can you upload or link to a picture?
I personally think that XFX already has a good painting. Anyways, I think you should give me the 4890 for a few weeks - you know, so you won't get any paint on it...
As far as I know, Painting the heatsink shroud shouldn't yield higher temps. Just make sure your paint doesn't burst into flames at 90C.
It would be a nice touch to a custom computer, especially in a case where the shroud is visible.
oh sorry. i was thinking cpu heatsink, my bad. painting the plastic on the gpu should be fine
that plastic is what i want to paint
it does it has a bad ass thing but it kinda draws all the attention thanks to the red nature of ati cards and if you look at my redeemed build youll see what i am talking about.
ohhh yes why a few weeks we should just go for a month or two lol
well i am thinking using paint for cars or some of that engine paint they are made to withstand extreme temperatures i will do more research and once i decide and have enough gathered i shall inform you guys and maybe even show some final [product pictures
You want want to go with a aftermarket sink instead. IMO that would look better than a painted shroud. Either that, or you can buy a black sink from someone with an XFX card.
thanks to bill owen and his awesome build logs i found it here is the link to what i want to do think it will look cool or what?
http://forums.bit-tech.net/showpost....&postcount=305
That looks easy enough.
If that shroud comes off easy, I say go for it.
I sprayed my dvd drive black to stealth it in.
Ps. Your rigs tidy.
1 - 11 of 11 Posts
