1 - 7 of 7 Posts
Just built my first computer. Check it out Here in Rigbuilder I am currently downloading pcmark 7 so i will post some scores later. Currently I have my Amd 960t zoma overclocked to 3667 and unlocked on 1.308 voltage. With a corsair h60 cooling it with two 120mm fans. And comments or help is greatly appreciated. I am currently trying to understand why my temps are so high at 1.308 voltage. My temps max out at 54 C. Here is a screen.
Nice build for 900.
In Fan Xpert (if you have it) you can set the Chasis fan, which is the pump for the H60 (if I'm not mistaken), to a higher level which will make the liquid flow faster.
I just installed a fresh OS on my SSD and... Well let's say I forgot to set my chasis "fan" settings while I slept.
1 - 7 of 7 Posts
