1 - 8 of 8 Posts
some help please, i also need help with software to use for the graphic card as i dont have any, as u guys can tell im a noobie on this site <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick out tounge caps" class="inlineimg" />
OK mate you need a program called <a href="http://www.softpedia.com/get/Tweak/Video-Tweak/GeForce-Overclocking-CoolBits-Reg.shtml" target="_blank">Coolbits</a>, install it and then you can start your adventure from there. Have a read of <a href="http://www.overclock.net/faqs/12423-how-overclock-using-nvidias-own-driver.html" target="_blank">this</a> and <a href="http://www.overclock.net/faqs/99694-how-use-coolbits-after-91-31-a.html" target="_blank">this</a>.<br><br>
Enjoy<img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
Hello to overclock you need this to enable the registry commands so you can change clock speeds. <a href="http://nvtweak.laptopvideo2go.com/" target="_blank">http://nvtweak.laptopvideo2go.com/</a> also make sure your graphics drivers are up to date here. <a href="http://www.nvidia.com/object/winxp_2k_91.47.html" target="_blank">http://www.nvidia.com/object/winxp_2k_91.47.html</a> When you overclock go up in 5-10 mhz increments depending on your card. Your card should go up pretty high. After every 2 to 3 tests play a game for a bit. And check the temperature settings tab under your 7600gt tab. Also just to tell you, under the tab overclocking settings. It will show you the clocks there go to manual overclock. Then agree to the terms, right after that you can get to overclocking. under the overclocking bars remember to check fan always on and apply on startup. Apply ok ok and your done<img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
Discussion Starter #5
ok i downloaded the program now what lol? also what program do i use 2 check the temp of the gfx card? i have no idea..
Use Nvidia Monitorto check the temps, it is part of the Nvidia Control Panel SOftware that you can download from theyr site.<br />
This software also alows you to overclock ,and test for artifacts.
Discussion Starter #7
umm im still confused <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick out tounge caps"> any1 get on aim or msn and guide me? <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick out tounge caps">
1 - 8 of 8 Posts
