1 - 7 of 7 Posts
When ever my computer is loading games, it gets really load. it never use to do that before. It sounds like it is going to blow up ):
What are your CPU / GPU temps while playing games?
When is the last time you have opened it up?
It could be dust has clogged up the heatsink on your CPU/GPU. This would cause the fans to have to run at a higher RPM.
Also, what kind of a noise is it? (Fan noise, buzzing, clicking, humming,etc.)
Fan noise the heat isnt that bad(can remember what the exact temps are) i think it might be dust i will check tommarow and tell u when ever i do it.
29 Cans of Ravioli
u load lol u rite u rite
if temps are fine it's probably not dust. dust doesn't make noise.
Are you using a stock air cooler?
Maybe the cpu gets real hot, than the motherboard ramps up the pwm fan(s)(if you have one) to 100% to cool down to a more cpu desirable temperature.
Open up After Burner and check the fan speed(%) of your gt 220. That could be the problem if its getting too hot.
1 - 7 of 7 Posts
